Thanks for the advice,
sounds like I've got some work to do :-(
The model is the drone that came with the Revell SR-71 kit. I've only been modelling for about 2 years and there are some areas where I need to get some focussed practice and experience.
Seams and gloss paint were two areas that had been high on my list for a while - and after a quick look for something "easy" but requiring seam work and with a mix of flats and curves and very few detail pieces the drone looked to be a good choice. Then the primer problem - ah well I wouldn't be modelling if I didn't like a challenge from time to time!
Thanks for the advice on the rattle can handling - I'd been reading up (and have done some rattle work before) so I'd warmed and shaken before use (my normal routine is to shake while dead heading the plants in the garden, warm in water while drinking a coffee, then shake while de-slugging the salad beds) before heading into the garage (British garage - so think draughty wooden shed full of junk) to spray. The lumps definitely result from not getting sufficient paint down to allow it to fully cover the plastic as I had primied a Helo before switching to the drone when the rattle can gave out and the Helo looks fine. (oh and it was definitely a warm dry day as I don't go near the garden under any other conditions.)
The rattle can had been sitting for a while before I used it, it was about a year old from the store and about half full. But it was given a very good shake, there's still content in there so I guess there is something solidly lodged in the spray mechanism. Triarius, Thanks for the advice on trying to clear the blockage. I haven't been able to clear it, so the can is on its way to the dump.
mfsob, I'm trying to stay away from strong chemicals :-) so I'll go with trying to sand the primer clear - it'll help that the drone has no awkward areas for sanding. I wasn't sure if it was worth attempting or if there would be an inevitable bumpy finish, but I guess I could end up sanding right back to the plastic. I'm investing in some fine wet-n-dry and blocking a couple of days in my diary.
Thanks again for the advice
