Alclad 2 'grit' / 'dust'
Posted by Anonymous on Friday, September 21, 2007 1:51 PM
Hi,
I was putting a finish of polished alunimum on my Trumpeter 1/72 F-107 Ultra Sabre, using Matt Swan's technique (Krylon gloss black for primer).  When I applied the Alclad I noticed after the first couple of coats a dark grey-ish 'grit' accumulating in areas like the wing roots and other nooks and crannies.  It looks sort of cool in the gun-ports but elsewhere its just looking dirty and is annoying to clean out.  I've not read about this anywhere and since I was hoping to get a nice polished look its rather disappointing, even if I am getting an otherwise decent alunimum look.  Anybody heard about this? Have techniques / stories to share?
Snowbird
    May 2007
Posted by Konig Tiger on Saturday, September 22, 2007 7:16 PM
Hi, to me it sounds like overspray. this is due to your spraying position of your airbrush and pressure. if you are spraying up the wing towards the fuselage the unused paint is being blown ahead of your airbrush and settling against the model. You made need to adjust the way in which your approach the spraying side when using alclad. Also the metaling appearence may be too much paint and the particles are settling out of the paint solution before properly drying, again this can be attributted to technic as alclad is a great product but can be tricky if you try and put to much on in one go.
I don't know how much experience you have with the product or airbrushing so don't take this the wrong way as I am only trying to guide you not belittle you. Cheers Jim
Posted by Anonymous on Tuesday, September 25, 2007 1:41 PM
No offense taken at all Jim--thanks very much for the helpful advice.  I'm not entirely new to airbrushing but recently got my first good quality Iwata setup and am still getting used to it.  I found that lowering the air pressure helped a lot with Alclad, which I've used on several projects before, albiet never on an entire airframe.
Cheers,
Snowbird
    December 2003
Posted by hkshooter on Tuesday, September 25, 2007 2:04 PM
I have to agree with the above post. I've had the same problem with spraying primer and the result, while kinda neat is not what one generally needs at the time. I've never had the problem with Alclad though. I typically spray it around 12 psi.
    January 2007
Posted by Gigatron on Tuesday, September 25, 2007 2:48 PM
I've encountered the same issue with Alclad.  I know for a fact it wasn't an issue with the primer coat.
I just ordered some polishing pads from micromark.  The kit has pads that are 2400, 3200, 6000, 8000 and 12000 grit.  I'm hoping I can buff out the problem areas.
-Fred
    April 2005
Posted by wing_nut on Wednesday, September 26, 2007 7:21 AM
The regular Alclads seem to take buffing with a fine grit pad pretty well.  I recently used a 3200 Micro-Mesh pad on it and you could not tell where it was "sanded".  After the area is smooth you can hit it the area again with the AB and it should blend in and disappear.
Marc
