I have seen the light in the Future! But?
Ant
    July 2007
Posted by Ant on Friday, September 21, 2007 6:26 PM
i have read about future so much since i have joined this forum and until yesterday i was in the dark. thanke to swanny i have found Future in Australia, here it is Pledge One Go.
Now i cannot believe the difference in the clear parts!!!!!! it's amazing, however a few questions.
i did a practice run on an old kit, i base coated, futured and decaled in an hour!!!( i know this is wrong just practice) Now i have coated my current model, but some questions.
how thick do i apply the future? i did one coat but i could still feel roughness in the paint and see the rough finish. i put some more on and have got mostly a full gloss, but can still see a bit of the rough flat finish although the kit feels smooth to run my hand over.
when i did the test run i didnt really care so i gave it a real good coat of future and it seemed to dry with a very smooth high gloss. So should i go back and give the kit another thick hit or decal then recoat?
on a final note i wish to thank everyone on this forum for thier help since i have joined it has made my modelling a absolute joy, thank you.
    May 2003
Posted by kirk4010 on Friday, September 21, 2007 9:44 PM
I always do 2 light coats, the model looks glossy and is smooth to the touch.   I typically wait  at least 48 hours before I decal.
The art of war is simple enough. Find out where your enemy is. Get at him as soon as you can. Strike him as hard as you can, and keep moving.-Ulysses S. Grant
Posted by ABARNE on Sunday, September 23, 2007 2:01 AM
I always spray reasonably light coats.  If you spray a heavy coat, you really run the risk of runs, particularly because Future won't dry in the nearly instaneous fashion that paint does.  I usually spray two, maybe three coats of Future, waiting perhaps an hour or two between applications.  Mostly, I want it to be dry to the touch before spraying a second coat.  I then usually wait overnight before applying decals, to really let the stuff cure.  Remember that being touch dry and chemically cured are two differerent things.
After applying decals, I wait again untill the next day and wipe with a damp cloth to remove any dried decal setting solution.  I read once on a forum from someone who had stains appear years afterward where the decal solution had been, so I take that precaution.  After drying, I spray another coat of Future over the decals to give a uniform finish over the decals.
