future is self leveling and should even it self out. If you are getting a "grainy" finish you may have exposed flaws in your under coat.
Did you thin the future? If so what did you use?
Did you use windex to clean your A/B (if you even used an A/B)? If so did you clean out the windex with distilled water? Windex wreaks havoc on future.
What Pressure are you spraying at?
Did you clean the surface before you futured?
Hmmm...answer these questions and maybe we can help you a little more!
