MM vs. Testors Rattlecans
    January 2004
Posted by st_gorder on Sunday, September 30, 2007 12:03 PM
Hey guys;
Are "MM Lusterless Flat Lacquer Overcoat #1960" and "Testors Dull Cote #1260 Flat Lacquer Overcoat" the same thing?  Been using the MM for a while and am happy with it.  Went to get more and got the Testors can.  Will it bring the same results?  I use Future as my Gloss coat over enamels acrylics.
Thanks'
Steve Gorder
    May 2003
Posted by qmiester on Sunday, September 30, 2007 7:54 PM
Since MM is part of the Testors product line, it wouldn't surprise me in the least.  I know that I have never had a problem with compatibility when mixing the two brands together.  I also believe that if you apply either when the humidity is high, you'll have probs with white spots/areas showing up in the finish.
Quincy
    January 2004
Posted by st_gorder on Wednesday, October 3, 2007 12:03 AM
Thanks Quincy
Steve Gorder
