Metal Cannon Kit
Metal Cannon Kit
Posted by jmcquate on Sunday, September 30, 2007 5:28 PM
I recently purchased the Guns of History (Britannia) metal Napoleon 12 Pounder field piech and a limber to go with it. What is the best type of paint for these kits?
    January 2007
Posted by IYAAYAS on Sunday, September 30, 2007 5:42 PM
You want to select a medium and stick with it.  Primer will be important it will help adhere the paint.  Also a real good washing with soap and water helps to remove any oils and such used to help release the metal from it's mold.  Prep is key, after that use what ever medium your comfortable with.  Acryl, enamel ect...
    May 2003
Posted by qmiester on Sunday, September 30, 2007 7:48 PM
Actually, there is no mold release on a molded metal item - the temps they are poured at are much too high.  With either sand casting or "lost wax" proceedures, the mold is destroyed when the object it contained is removed.  Priming was very important when most molded metals were lead or lead alloys.  If you didn't prime them, they would corrode beneath the surface paint.  Britianna metals don't contain any lead (to my knowledge), and in theory, don't corrode.
Having said that, when working with molded metal items (like figures) because they get handled by you (and quite possiblly the people who packaged the model) and skin oils are on them, I wash them in warm soapy water, let them dry and then prime - The primer also does a fine job of bringing out any defects you might have missed earlier.
Quincy
