Acrylics.... simply WOW!!!
    November 2003
Posted by TryintoModel on Monday, October 1, 2007 8:14 PM
Ok, I've been a die hard enamel paint user since I "seriously" got into building models.  I haven't attempted to use acrylics yet, especially for airbrushing.  I originally started, like most, hand brushing my models, which is, from what I gathered, easier to do with enamels.  Then I had all this enamel paint so I naturally started my airbrushing with enamels.  I know there is a big debate amongst some about enamel vs acrylics so I usually looked towards the pros about enamels and the cons about acrylics.
Anyway, I was finally forced to try airbrushing acrylics when my son wanted to airbrush one of his models.  I had always bought him acrylics to hand brush because they were safer.  It was hard for him to do a good job hand brushing acrylic paint, especially when he's only 7.
So, I thought this would be an opportunity to not only teach my son to airbrush, but also try out acrylics through my airbrush.  I thinned the plain ole testors acrylics with alcohol and WOW.  It was much easier to get a smooth spray.... I just couldn't believe it.  I have tried for so long to get a really good spray from my enamels.  I always thought it was just something I was doing wrong.  I have tried every thinner I could and in every ratio and never really got in consistently right.  My models looked ok, but the painting was never this easy.  I was much easier to get the right consistency and I could actually WORK the airbrush as opposed to what I used to do.  For a bonus, the paint dried super fast as opposed to the enamels I used to use.  We were able to paint several different colors, one after another, without worrying about it being wet.
I was just very surprised.  I'm not saying I'm totally going to change, but I'm definately going to delve into the acrylic world... but I may be sold soon.
Sorry for the ramble.
    August 2007
Posted by ben1227 on Monday, October 1, 2007 8:20 PM
Sounds like me! I'm in the process of converting to mainly Tamiya Acrylics since i got my airbrush. They smell nicer, clean up with non-toxic stuff (water!) and I just like them better. Brushing is a job for enamels still though...But I've found that Tamiya acryls do work pretty good for hand brushing because they require less coats than other acrylic paints.
.:On the Bench:. Tamiya 1/72 M6A1-K
    January 2007
Posted by Gigatron on Tuesday, October 2, 2007 8:35 AM
Welcome to the club.  But I have to warn you, once you really get into the acrylics, you may never airbrush enamels ever again.
My preference is for Tamiya acrylics.  They have a huge selection of colors and they seem to have a shelf life of dang near forever.  As long as you close them tightly when you're done, they'll last a good long time.  And if they start to dry up, throw in a little tamiya thinner (X-20A), stir it up and it's good as new.
-Fred
Posted by espins1 on Tuesday, October 2, 2007 10:40 AM
Ya, I used to be an enamel guy until I decided to try out Tamiya Acrylics about three years ago.  Now I use their paints exclusively.  They make it so easy to get a great paint finish, once you've had a chance to experiment with thinning ratios.  I find that I need to thin their gloss paints a little more than the flats, same thing with the metallics, just a little more thinner than the flats and I can consistantly get a perfect finish with them.  Plus they're just so easy to clean up!  All you need is windex (the ammonia disolves them like there is no tomorrow, even cured acrylic! Smile [:)])
Scott Espin - IPMS Reno High Rollers  Geeked My Reviews
    August 2006
Posted by HawkeyeHobbies on Tuesday, October 2, 2007 10:52 AM
I only use enamel now mostly for doing small delicate parts that I paint with a brush. Acrylics are great stuff no matter what type of scheme you are painting. Everything from Camo to NMF. Clean up is easier and far less odor!
Gerald "Hawkeye" Voigt
