The differences between a gravity fed AB and a siphon fed AB are smaller than you might think. Smaller in the sense that the gravity fed are more "capable" of spraying a thinner line, due to it's ability to use less air pressure. Otherwise they work pretty much the same.
Actually achieving that smaller line is more dependent on the user than the brush, especially with dual action. I have 3 brushes: 100LG, 150 and 200-20 (there is a difference between the 200-20 and the 200NH Ben listed above, I prefer the -20 version). In reality they are all variations of the same basic airbrush.
The 100 series is dual action and is available as SG (slotted cup holding just a few drops of paint); the G with a fixed 1/16 oz. cup; the LG with a fixed 1/3 oz. cup; and the SF Side Fed which comes with a 1/16 color cup and is available in left or right hand version. The SF has the added capability of being able to spray completely vertical which is a very nice feature. The 150 is a dual action siphon fed and comes with bottles and color cup. The 200 series is single action and comes as the SG (slotted cup) G (1/16 oz. cup) which are gravity fed and 200-20 (siphon fed with PPS metering system) and the 200NH (siphon fed with the New Head featured on the 155, 175 and 360). The New Head was supposed to eliminate the need to change needle and tips for finer lines, but I see Badger is now offering a "fine" regulator, needle and tip. I prefer to stick with the medium needle/tip combo for my brushes. I haven't had a good reason to exchange the tip and needle, yet.
The 100LG is considered a fine line AB, but I find the control of the dual action a bit fiddly (my fault, not the brush's) and I can spray a better line with my 200-20. That's due to it's PPS paint metering system more than anything else. Being able to dial in the thickness of line for consistant results is a huge benefit.
