Brush painting
CPO
    July 2006
  • From: Morganton,N.C. ( Foot hills of the Blue Ridge Mtns. ( on I-40 )
Brush painting
Posted by CPO on Wednesday, October 10, 2007 12:57 PM
Somebody tell me an easy way to paint the top part of the model one color and the bottom part a different color????
Thanks, CPO
Charles P. O'Brient aka CPO
Posted by ABARNE on Wednesday, October 10, 2007 2:05 PM
First, paint the top part of the model one color.  After waiting for that coat to cure (usually the next day), paint the bottom part of the model a different color.  If the color demarcation is supposed to be hard edged, mask the top color with Tamiya Yellow masking tape.  To alleviate paint bleeding, try not to really pile up the paint on the edge of the masking tape.  Brushing away from the tape edge helps.  If the color demarcation is supposed to be soft, use a bit of foam rubber, and carefully stipple the edge with it.  If you keep the foam fairly dry and do overload it with paint, you can achieve a decent soft edge.
    May 2005
Posted by Bgrigg on Wednesday, October 10, 2007 4:26 PM
Sign - Ditto [#ditto] Man I wish they could fix the spelling on that sign!
edit Thanks to MusicCity I have a CORRECTED Ditto Sign! Thanks Scott! /edit
I'll add that you should paint the lighter color first, regardless of top or bottom, otherwise Abarne was spot on.
So long folks!
    January 2007
Posted by IYAAYAS on Thursday, October 11, 2007 5:01 AM
one thing to point out, make sure you allow the paint to cure at least 48 hours untill applying any masking tape.  You'll pull the paint off if you don't.
CPO
    July 2006
Posted by CPO on Thursday, October 11, 2007 9:07 AM
Thanks Abarne,I will give your suggestions a try......CPOSmile [:)]
CPO
    July 2006
Posted by CPO on Thursday, October 11, 2007 9:09 AM
Thanks Bgrigg for the suggestion.....CPO Smile [:)]
CPO
    July 2006
Posted by CPO on Thursday, October 11, 2007 9:11 AM
Thanks for the suggestion.......CPO Smile [:)]
