little help with the AB!
    May 2005
Posted by IceDragon122 on Friday, October 12, 2007 11:08 PM
ok just got done spraying with MM Acryl and i love the results!  but for some reason, i kept getting massive tip dry even at low psi.  it got so bad that it created a clump on the needle!
 Never happened to me with enamels, but i can no longer tolerate the fumes with those guys.
 Anyways....should i go out and get acrylic retarder for this?  if i can use acrylic retarder, how much do i use? (im really new to the world of acrylics!)
 Also.......after airbrushing......i did smell a faint trace of the acrylic fumes....it was way minor than what the enamels gave off!
OH! almost forgot....do i wash these acrylics down the sink or should i put the wastes in a can, then let them evaporate?  im really new to these paints and think i like them!
 Thx! for the help!
-Brian
    May 2005
Posted by Bgrigg on Friday, October 12, 2007 11:19 PM
MM Acryl is notorious for tip dry. Get some Liquidtex or Createx Acrylic retarder and put a drop into the thinner you use, then add to the paint. Should put an end to tip dry.
Just in case though, keep a little cap of Windex and a Qtip handy. When not spraying, swab out the regulator (pull the needle back first) and tip dry should be nothing but a bad memory.
You can dump the paint down the drain, that's the nice thing about acrylics. Soap and water wash up your hands.
So long folks!
Posted by MikeV on Friday, October 12, 2007 11:37 PM
Tip dry is a way of life with acrylics and while using retarders and so forth helps there is not much you can do to eliminate it IMHO.
I suggest you become used to picking the paint off the needle tip with your thumb and fingernails as T-shirt artists do all the time. It keeps the needle fairly clean and allows the paint to flow better. Wink [;)]
