Between Coats
    February 2007
Between Coats
Posted by Adriaran on Tuesday, October 16, 2007 6:00 PM
Well I'm not too experienced at modeling yet, but right now I'm working on a simple model, just a straight Revell FW-190 from-the-box. I'm trying out my first attempts at good weathering, and I just finished spraying an aluminum undercoat so I can do salt weathering and make it look like the paint's chipped. I'm about to spray on the colored coat, but I was wondering, do I need to seal the aluminum coat so that when I salt weather it, water won't damage it?
    January 2003
Posted by Triarius on Tuesday, October 16, 2007 8:53 PM
What silver did you use? Most fully cured paints, regardless of type, withstand water pretty well if not immersed. Some aluminum pigmented paints will discolor if exposed to salt water and air for a sufficient time, especially the buffing metallics.
    January 2007
Posted by IYAAYAS on Wednesday, October 17, 2007 5:11 AM
Ok...whenever I have reach a point where a big decission needs to be made here's what I do"
What is the worst outcome that could happen? Is the possible outcome worth saving a little time?
In your case your under coat could be ruined (that's pretty bad)
Seal away!  IMO
    February 2007
Posted by Adriaran on Wednesday, October 17, 2007 3:07 PM
It's Model Master's Aluminum Enamel. No.1781
Well if I'm going to seal, what would you suggest I use?
