Can you thin MM enamels ith anything other than MM thinner?
    August 2006
Posted by IanIsBored2000 on Saturday, October 20, 2007 3:13 PM
Just wondering......I used to buy the black retangular cans of MM (model master) enamel thinner, for about 7 dollars.  It's not too bad of a price, but is there anything cheaper they can be thinned with? Also, is there anything better to thin them with?  Last, I ahven't used enamels in a while, so what would you suggest for a thinning ratio?  Thanks, Ian
"Scanlon: work your knobby hands on the table in front of you, constructing a make-beleive bomb to blow up a make-beleive world."
    December 2003
Posted by hkshooter on Saturday, October 20, 2007 3:22 PM
I used laquer thinner for many years to thin my enamels. Paint dries a little quicker that way. Plane jane old hardware store brand, about $8 a gallon. I did start using the original MM thinner again just because it seemed like the thing to do and I can afford it now. I still clean with the laquer thinner though.
    December 2003
Posted by hkshooter on Saturday, October 20, 2007 3:23 PM
Oops, I missed your other question. Ratios vary but I tend to thin 1:1 for most stuff and spray many light coats.
    March 2007
Posted by JMart on Saturday, October 20, 2007 3:35 PM
to piggy back on your question...
Do you clean your AB with lacquer thinner? I also have been thining my MM enamel with thinner or lacquer thinner and cleaning my HAND brushes with lacquer thinner... Recently started using an AB ans was wondering about lacquer thinner to clean the AB being too strong
Yes, I also thin with lacquer thinner, ok so far, dries faster as mentioned. I get the sunnyside plain lacquer thinner half-gallons at craft store or hardware store, depends what coupon I have at the momment!
Posted by ajlafleche on Saturday, October 20, 2007 3:53 PM
I have used plain old paint thinner from the hardware store for years. Couple bucks a gallon every few years does it. I use this to clean the AB when I shoot enamels, to thin oils and to clean my brushes when I use oil or enamel paint. I see absolutely no reason to spend $7 on a pint of thinner just because it says Model Master on the outside. I did get some at a yard sale once as a lot of paints and supplies. I found there was NO difference in  performance.
    August 2007
Posted by ben1227 on Saturday, October 20, 2007 4:47 PM
Don't buy the tiny little pint size thinner cans. I thought the $8 price was ridiculous when I can get lacquer thinner from the hardware store for far cheaper.
.:On the Bench:. Tamiya 1/72 M6A1-K
    August 2006
Posted by IanIsBored2000 on Saturday, October 20, 2007 5:04 PM
Glad to hear it! I'll have to pick some up...actually, odds are my dad's got some somewhere in our basement/shed/workshop/boathouse/garagy thingy.  You wouldn't beleive the stuff I find around here!  Thanks again.
    February 2006
Posted by Wilbur Wright on Saturday, October 20, 2007 5:55 PM
Just to chime in and save someone some money.......I use oderless mineral spirits (paint thinner) from Home Depot and have for many years.  It works fine. An $8 gallon will last for three years.
Posted by ABARNE on Monday, October 22, 2007 1:50 AM
I've always used Kleen-Strip Mineral Spirits which one can buy for about 2 bucks per quart at the local hardware store, and have never had any issues.  Recently, I bought a bottle of MM airbrush thinner just to see if there was any poosible advantage to using it, and I found no difference between it and the generic stuff.
For additional cost savings, you can reuse your thinner for cleaning.  I have a couple of spaghetti sauce jars that I keep my used thinner in.  I put dirty thinner into one jar.  After a few days, the paint particulates will settle out into a sort of sediment on the bottom of the jar leaving clear thinner above.  After I've collected enough thinner, half a jar or so, I carefully pour off the clear thinner into my other jar which then becomes my source jar for cleaning thinner.  The thinner does take on a sight greenish hue, but cleans brushes and airbrushes fine.  By recycling that way, I can literally get years of use from a quart of thinner.
From my experience, I don't think there is a useful thinning ratio that can be applied to Model Master enamel because there is too much batch to batch variation, even for bottles of the identical color.  I have occaisionally had bottles that sprayed perfectly straight from the bottle.  I have had other bottles in which the paint was so thick that I had to add a lot of thinner (maybe four or five parts thinner to one par paint).  I think you have to treat each paint individually and add thinner as needed until it's properly reduced for painting.
