Is there anyway to THICKEN paint?
    June 2007
Posted by Col_Shaggy on Thursday, November 8, 2007 8:07 PM
I've got about a quarter bottle of Testor's Model Master Light Gray FS36495 that I thinned to run through my airbrush. It covered pretty well with the airbrush but now I have some touch up to do and what I have left is too thin to brush properly. I don't want to buy more of the color because the amount of paint for each color, I originally purchased for this project, has been just right and after this is done I think I'm going to quit using oils for awhile.
Is there anything I can do to bring it back to its original thickness without messing up the color?
There are no masterpieces. Everything is training. - Me
    December 2003
Posted by hkshooter on Thursday, November 8, 2007 9:08 PM
Leave the cap off overnight.
    October 2005
Posted by usmc1371 on Thursday, November 8, 2007 10:24 PM
You could try touching up using the airbrush.  I sometimes take a business card, cut out a small opening about the size of the area I need to touch up and use that as a mask to airbrush the affected area.  Just don't touch the business card to the surface of the model.  Maybe keep it about 1/8th inch away.
Jesse
    January 2003
Posted by Triarius on Friday, November 9, 2007 9:20 AM
Solvent loss through evaporation is about the only possibility. I suggest you take a small amount from the bottle and put it in an open container (an empty bottle will do) and stir periodically for several hours. The stirring is needed to keep it from skinning over.
This is another reason to only reduce the amount of paint needed for immediate use, leaving the original paint in the original bottle.
    June 2007
Posted by Col_Shaggy on Friday, November 9, 2007 10:05 AM
Thanks for the replies.
I had a large area to cover with the color and I knew that, inevitably, I had would have to use most or all of what was in the bottle, it's only a half ounce bottle. What I dumped back in was what was left in my airbrush bottle after the last coat, the paint bottle itself was pretty much empty.
The airbrush idea is out simply because I'm out of air, it's just a Kustom Kolor airbrush kit I got from Walmart for $30.00, and I don't want to spend another twenty for a bottle of propellant that I won't even use a quarter of.
I hadn't even thought of letting it dry out a bit, my thinking was that paint had two states dry and wet, when I was trying to figure out what to do. My one track mind I guess.
    May 2003
Posted by qmiester on Saturday, November 10, 2007 3:29 PM
I've noticed that if you have some paint that you have thinned for airbrushing and not used, if you let it set a couple of days (in a sealed bottle), the pigment and the carrier tend to seperate.  You might try to siphon out a little of the carrier with an eyedropper.  Just a thought.
Quincy
    August 2007
Posted by ben1227 on Saturday, November 10, 2007 4:54 PM
Sign - Ditto [#ditto]
Enamels and acrylics separate like that, and I'd suggest the same.
.:On the Bench:. Tamiya 1/72 M6A1-K
    January 2003
Posted by Triarius on Saturday, November 10, 2007 5:19 PM
The problem with that is that the "carrier" is the binder, and it usually doesn't separate from the solvent nearly as fast as the pigment. So what you are siphoning off is both binder and solvent.
    June 2007
Posted by Col_Shaggy on Tuesday, November 13, 2007 8:45 PM
I let it sit open for awhile and was able to get just enough that was thick enough to do the touch ups so I'm beyond that stage now.
Thanks for all of the advice, though, I'll definitely keep it in mind for next time.
Posted by gjek on Wednesday, November 14, 2007 12:02 AM
I was thinkin to just add some cornstarch and heat it a little bit, or was that for gravy....
Msgt USMC Ret M48, M60A1, M1A1
Posted by MikeV on Wednesday, November 14, 2007 4:09 PM
That would be gravy my friend! Laugh [(-D]
    January 2007
Posted by Deputy_Brad on Wednesday, November 14, 2007 6:01 PM
Why couldn't you just apply a few thin coats by brush until the colour was opaque?
My real name is Cam. Interest: anything 1/72, right now mostly sci-fi and modern In progress: 1/72 Sci-fi diorama (link in my web) 1/72 Leopard 2A5 1/72 APC Conversion to a MEGA DESTROYER
