Question: - Masking Wheel Wells
cml
    March 2007
Posted by cml on Thursday, November 15, 2007 10:38 PM
G'day all,
 Just wondering how others out there mask wheel wells when airbrushing.
I have a method, that is ok, but not great and would like some imput from others.  Basically, what i do is cut strips of tape and fix them along the vertical walls of the wells, i then (depending on the depth of the wells) fill the well with cotton wool, or, if shallow, paint it with maskol.
 The only problem is, i tend to get some paint bleed under the tape (no matter how careful i try to be).  Obviously this is because, wheel wells are usually odd shapes and the tape doesn't tack down as well as on a flat surface.
 If anybody has a better way, i'd love to hear it (as i'm sure others out there would too).
thanks,
cml
Chris
    May 2005
Posted by Bgrigg on Thursday, November 15, 2007 11:01 PM
I've successfully used two different methods.
One is to use wetted Kleenex to fill the cavity. Paint and then re-wet the Kleenex to remove. Kleenex (or other tissue) is better than paper towel, which is too stiff.
The other method is to paint the underside of the wings first, then mask the wings to paint the wells. I've used the poor man's Parafilm: Glad Press'n Seal to good effect.
So long folks!
cml
    March 2007
Posted by cml on Thursday, November 15, 2007 11:37 PM
Bgrigg,
 Thanks for the suggestion, just two quick questions:
1.  Why do you need to re-wet the tissue to remove?  I assume that you paint the cavity first, then fill and paint the wing?  Would this pose a problem (ie, wet kleenex) when using acrylics?
2.  I've heard of parafilm, but am at a total loss as to what it actually is or where to get it (i have a suspicion it might be marketed under a different name here in Australia)...
 Cheers mate,
cml
Chris
Posted by MikeV on Thursday, November 15, 2007 11:58 PM
That's how I do it and I use Tamiya masking tape or 3M blue tape. I burnish the edges of the tape good with a toothpick or other flat instrument and I never see bleed under.
    October 2007
Posted by sizzlak on Friday, November 16, 2007 11:34 PM
I use Sticky Tack (Blu Tack) on areas that are oddly shaped or hard to reach. You can get it at most office supply stores. It can be reused after paiting, unlike masking tape, and it won't pull off already painted sufaces.
http://www.blutack.com/
    January 2007
Posted by IYAAYAS on Saturday, November 17, 2007 5:16 AM
Sign - Ditto [#ditto] except I used silly putty.  Works great, you can stick a tooth pick in it and use it as a handle as well.
    May 2005
Posted by Bgrigg on Saturday, November 17, 2007 10:46 AM
By wet I mean wetted and wrung out (well, as best you can with a flimsy material!). That helps to form the Kleenex into the corners and recesses. The dampness doesn't affect acrylics at all, as long as you leave it in place while the paint dries. Of course that means the Kleenex dries as well, and that can make it difficult to remove from convoluted areas. The re-wetting allows the Kleenex to become flexible enough to remove without damaging anything, and won't bother the dried paint at all.
I use this method mostly for cockpits now, and prefer the second method for most wheel wells.
Parafilm is sold by laboratory supply merchants, and they have an Australian contact. It's a plastic film with a wax like substance to allow it to hold and seal. It's not cheap, but it is worth the money! Glad Press'n Seal is a similar household product, but doesn't work quite as well. Its saving grace is the availability and low price. I couldn’t find a like product on Glad.com.au website, so you might be out of luck.
You could easily use Tamiya or similar tape (I have yet to find a tape as good as Tamiya, though). As MikeV said, burnish it down well to prevent the paint from bleeding under.
So long folks!
    October 2005
Posted by tabascojunkie on Saturday, November 17, 2007 1:59 PM
Another vote for stuffing them with Silly Putty. Works really well and easy.
Bruce
cml
    March 2007
Posted by cml on Sunday, November 18, 2007 10:03 PM
Thanks everyone for your suggestions - it's given a range of different options and ideas.
Also, thanks for Bgrigg for the info on Parafilm.  I might see if i can find the glad product in a local supermarket.
cml
Chris
    August 2006
Posted by HawkeyeHobbies on Monday, November 19, 2007 7:51 AM
Just remember that when using Parafilm or Glad Press n Seal it works best if it is warm. I keep the Parafilm near my body to warm it or place it above the fluorescent fixture over my bench. Warming it to above 90 degrees F is all it takes. The warm softens the wax in the Parafilm making it sticky. It helps the PnS stick better as well.
Gerald "Hawkeye" Voigt
Posted by MikeV on Sunday, December 2, 2007 2:41 AM
I forgot about this tip.
Go to the store and buy a pack of those sponges that women use to put on makeup.
Cut them to size and stick them in the wheel wells with tweezers or a toothpick.
They are dense foam rubber and soft so they conform great.
The ones my wife picked up for me are similar to these:
http://www.drugstore.com/qxp78162_333181_sespider/rite_aid/cosmetic_make_up_wedges.htm
    February 2006
Posted by Wilbur Wright on Tuesday, December 4, 2007 6:39 PM
Cotton Balls
