chef_ben wrote: |
1: When the black dried the coat I applied crack like crackle paint. I'm guessing it was too thin? 2: The gauge on my compressor is 0 to 160 so its hard for me to tell what my pressure is. Any ideas? 3: Couldn't get a super fine line to save my life with the tan tip. Is this also because of two thin a paint? |
Here's my input...
1. There are many possible reasons for the effect you experienced. My own personal opinion would be the fault lies with the plastic bottle more than your paint. Generally, two-liter plastic bottles are intentionally manufactured with a plastic that has 0% porosity...it's a health thing. Try practicing on either spare model part, spare styrene, or a more "industrial" type of plastic. I've heard of some modelers using the sides of their Rubbermaid storage containers.
2. I would recommend putting in a second air gauge. I have this set-up on my compressor. First is the gauge that came with the compressor and this stays set at about 40 psi. Next, I have an airbrushing gauge and this is the one I actually adjust for differing airflows. Then the airbrush line is attached. Generally, with the Aztec, I spray most basecoats, Future, etc. at around 12 to 15 psi. For more detailed applications, I'll thin the paint some more and spray between 5 and 10 psi.
3. Please define, "Super Fine". If, as I suspect, you're trying to get uniform lines of something like 1/16", I think you're not going to be happy with this. In general, the smallest uniform, consistant lines I've been able to get with the Aztec are about 1/8" or just slightly larger. These are done with very thin paint and spraying at pressures around 5 psi. As the pressures increase, the overspray on the edges increase. Additionally, as the paint gets thicker, you need to increase the pressure to push the paint through the brush.
The whole key is practice, practice, practice. Even after 5 years, I'll still experiment with different paint formulations and air pressure settings to try different effects.
Hope this helps...
