IYAAYAS wrote: |
sure for cleaning up around the work bench, spills and such...alcohol works better. but running alcohol through your ab dries the seals out much quicker than windex. |
That would depend on the material in the seals. All common paint solvents (even water!) are aggressive to both natural and synthetic elastomers. Ammonia, the main thing that differentiates Windex from isopropyl alcohol, is extremely aggressive to many elastomers, and will readily attack brass, the metal from which most airbrushes are made.
However, the materials used in the seals of most good quality air brushes these days are chosen for their resistance to common solvents, including ammonia (which is often a component of some water-solvent type paints, chiefly latexes and acrylic latexes). The ammonia in Windex will attack the metal in the airbrush faster than it will attack the seals.
No seal material is resistant indefinitely, and alcohols are defatting agents. All alcohols will eventually attack the lipid-like components that make flexible elastomers flexible.
In terms of equipment durability, it doesn't matter which you use provided you rinse the airbrush thoroughly with a neutral solvent before storing. This means water for acrylics, and usually mineral spirits for enamels and lacquers, as it is the mildest solvent in its class. For long term storage, following the mineral spirits with a detergent or soap and water wash and rinse and thorough drying is a good idea.
You can also rinse with ethyl alcohol. Ethyl is the alcohol least aggressive to most elastomers.
