MisterKit thining?
    August 2007
MisterKit thining?
Posted by rong on Thursday, November 29, 2007 8:31 PM
I just bought some acrylic MisterKit paint (Luftwaffe WWII) and wondering if any one here has info on what thinner(if any) can be used since there is no info provided on the bottles.  I will be airbrushing (fine needle).  I checked this forum and googled but did not find anything conclusive.
Ron
    February 2006
Posted by ruddratt on Thursday, November 29, 2007 8:45 PM
I've used their WWI colors, and they're really nice. As they can separate during storage, be sure to stir (not shake) them real well before you use them. They can be thinned with just about any commercially available acrylic thinner (I use Tamiya's). Distilled water or isopropyl alcohol work well too, but if you don't add a retarder to either of those, tip-dry is a possibility.
 "We have our own ammunition. It's filled with paint. When we fire it, it makes pretty pictures....scares the hell outta people."
    August 2007
Posted by rong on Friday, November 30, 2007 8:34 AM
Thanks for the help.  I've got all those thinners so I'll go with the Tamiya.  I look forward to trying them out.  They have a nice selection and at the time I ordered them they were the only ones in stock.
Ron
Moderator
    April 2006
  • From: my keyboard dreaming of being at the workbench
Posted by Aaron Skinner on Friday, November 30, 2007 8:46 AM
When I tested MisterKit for the magazine, I found them to be good paints, if a little different from what you are used to. I tryed them with a mixture of equal parts isopropyl alcohol and distilled water and when the paint was thinned correctly they went on very well. Nice line of paints with a lot of colors not available elsewhere.
Cheers
Aaron Skinner
Editor
FineScale Modeler
    January 2003
Posted by Triarius on Friday, November 30, 2007 9:11 AM
Aaron, I've read your very good artilcle on acrylics, and I have a question: Why did you choose to mix two different solvents when thinning the paints?
    August 2007
Posted by rong on Friday, November 30, 2007 9:18 AM
Thanks Arron for more good info.  When I googled I found a post on another site where someone uses floquil.  It appears that MisterKit is quite tolerant of a variety of solvents.  I have not been at this for very long but I have tried most of the paint brands and so far I like Gunze the best for fine airbrushing as well as excellent color renditions.  I look forward to seeing how MisterKit works out.
Ron
Moderator
    April 2006
Posted by Aaron Skinner on Friday, November 30, 2007 9:54 AM
Ron,
I like Gunze a lot – it goes on well, thins easily, and seems to be pretty tough. My usual choices are Gunze, Tamiya, Polly Scale, and Model Master Acryl in about that order depending on what color I need. These other ranges like MisterKit and Lifecolor are great because they often have color the other ranges don't. If you build WWI aircraft, MisterKit is the range for you.
Cheers!
Aaron Skinner
Editor
FineScale Modeler
Moderator
    April 2006
Posted by Aaron Skinner on Friday, November 30, 2007 11:56 AM
Ross,
The short answer is I got that from the MisterKitUSA's Web site:
http://www.misterkitusa.com/98383f87-6c16-4433-8caf-5f33fbcb6200-9.html
They also suggest using any commercially available acrylic paint thinner which I did not try but would probably work. In the bottle, the paint smells a little like acrylic house paint.
Aaron Skinner
Editor
FineScale Modeler
    January 2003
Posted by Triarius on Friday, November 30, 2007 12:14 PM
Most interesting. When I get around to it, I'm going to test them for compatibility with each, separately.
