My Badger is broken I think :(
    January 2007
Posted by Deputy_Brad on Sunday, December 2, 2007 2:33 AM
I just bought my Badger Anthem about 2 months ago on sale. About 2-3 weeks ago I was putting it back together and I think I stuck the needle in too far and stretched out that cone piece. Now when I try to do fine lines I get a donut about 2-3mm across. I have noticed the needle sticks out a bit farther now than it did when I first got it too. What should I do?
My real name is Cam. Interest: anything 1/72, right now mostly sci-fi and modern In progress: 1/72 Sci-fi diorama (link in my web) 1/72 Leopard 2A5 1/72 APC Conversion to a MEGA DESTROYER
Posted by MikeV on Sunday, December 2, 2007 2:39 AM
Go to a hobby shop if you have one and buy a new cone (tip) for it.
DHM
    September 2007
Posted by DHM on Sunday, December 2, 2007 8:36 PM
If you can't find it there, check this webpage: http://www.dixieart.com/155_Anthem_Parts.html
I suggest buying a new needle as well.  No telling what happened to it durring the incident.
    May 2005
Posted by Bgrigg on Sunday, December 2, 2007 8:54 PM
In fact, buy two needles, never hurts to have spares! While you're at it, get some needle lube!
http://www.dixieart.com/Badger_Airbrush_Main.html#anchor1245
http://www.dixieart.com/Iwata_Airbrush_Main.html
So long folks!
Posted by MikeV on Sunday, December 2, 2007 9:07 PM
Great advice get spares! Thumbs Up [tup]
    January 2007
Posted by Deputy_Brad on Wednesday, December 5, 2007 11:51 AM
Great thanks for the replies. Im not really into buying and ordering online so Ill go to the LHS sometime soon. I noticed that my cone size is a medium I think? Am I able to get finer tips?
Also the cone appears to be in there pretty snug and Im afraid to take any pliers to it.
Posted by MikeV on Wednesday, December 5, 2007 12:30 PM
The Anthem and Badger 360 both use a single needle/tip so there are no other sizes you need.
If the cone is in there stiff try soaking it to see if it will come loose. Sometimes they need some persuasion to get out. If you get the new tip then take some pliers and pull the other one out as it will be thrown away anyhow.
    December 2006
Posted by Grahor on Friday, December 7, 2007 8:51 PM
Anthem has recently got a fine tip and a fine needle too, as far as I can judge from Badger's site, so it has now 2 tips it can use - medium and fine.
But most people don't need fine tips. On the other hand, it doesn't hurt to have one to train and check if you need it.
