Paintbooth
    November 2007
Paintbooth
Posted by modlvr on Thursday, December 6, 2007 5:25 PM
Well after trying an airbrush for the first time it quickly became apartment that I needed a paint booth if I wasn't going to kill myself.
I didn't want to spend a ton of cash with Christmas coming so I elected to build one.
 I am in a one bedroom apartment and really cramped for space between my office and hobby area.
Anyway I built this for under $50.00 out of an oven hood I got at Home Depot and a Plastic storage box I got a Wal-Mart.
If there are any children in the room send them out now. It is fairly grotesque Big Smile [:D]
I used it for the first time today. Geesh I just built it yesterday... and it worked great.
BTW I have put up a hobby site and started a blog on my first model build in over 35 years. Fell free to register and comment. I need all of the help I can get.
http://www.andyshobbies.com
Positive comments, advice and constructive critisism glady accepted.
Andy Creativity is allowing yourself to make mistakes. Art is knowing which ones to keep. Scott Adams, 'The Dilbert Principle' www.andyshobbies.com (Not a store) modeler@andyshobbies.com On the bench. Tamiya F4U Corsair
    August 2006
Posted by HawkeyeHobbies on Thursday, December 6, 2007 5:44 PM
Looks good Andy, you'll find ways to tweak it as time and use occurs. As long as it works.
Gerald "Hawkeye" Voigt
    December 2003
Posted by hkshooter on Thursday, December 6, 2007 6:17 PM
I'm crunched for space too and I gotta tell you, yours is nicer than mine. Fine job on the improvising!
    February 2005
Posted by RadMax8 on Thursday, December 6, 2007 7:58 PM
Andy, there's one more expense you need... BUY A RESPIRATOR! They're pretty cheap at the Home-improvement stores, and well worth what you'll spend! Mine's a 3M brand. That will take care of the fumes your spray booth doesnt get!
Your spray booth looks better than my original one... it was a box i made out of CHEAP plywood in my basement and an old fan with a furnace filter... lol
    November 2007
Posted by modlvr on Thursday, December 6, 2007 9:11 PM
Thanks.
I already have a resperator that I use when painting nylon for kites.
    February 2005
Posted by RadMax8 on Thursday, December 6, 2007 9:49 PM
Outstanding!Big Smile [:D]
What kind of paint do you use to paint nylon??
    November 2007
Posted by modlvr on Thursday, December 6, 2007 10:15 PM
Design Master Spray.
    March 2007
Posted by kcmat on Thursday, December 6, 2007 10:55 PM
off topic but whats your avatar from modlvr?
http://www.myspace.com/madmat77
    November 2007
Posted by modlvr on Thursday, December 6, 2007 11:03 PM
World of Warcraft.
    October 2003
Posted by ModelNerd on Thursday, December 6, 2007 11:44 PM
A word of caution! Basic vent hood and bathroom fans, such as those found at Home Depot, are not typically recommended for the removal of volatile fumes, and can ignite the vapors, causing loss of eyebrows, or much worse. You really should use a "shaded pole" fan/motor, these are available at www.grainger.com . Shaded pole motors (EDIT: most shaded pole motors with a squirrel cage setup) are isolated from contact with ignitable vapors.
- Mark
Posted by MikeV on Friday, December 7, 2007 12:17 AM
 ModelNerd wrote:
Shaded pole motors are isolated from contact with ignitable vapors.
Actually they are not guaranteed unless it specifically says, "Explosion proof" on the motor and those are very expensive.
    March 2007
Posted by kcmat on Friday, December 7, 2007 12:25 AM
 modlvr wrote:
World of Warcraft.
Hehehe thats what I thought. I play Horde on Azgalor server.
    October 2003
Posted by ModelNerd on Friday, December 7, 2007 1:14 AM
Yes, Mike is quite right. Make certain it's rated as explosion proof. Expensive, yes. But it's even more expensive to go to the burn ward, so it's money well spent.
At the very least, a "squirrel cage" type arrangement (where the actual motor is not in the airflow stream) should greatly reduce the possibility of a spark ignition. These can be purchased quite a bit cheaper.
- Mark
Posted by MikeV on Friday, December 7, 2007 2:36 AM
I agree Mark that a squirrel cage is really all you need.
The only way a paint booth is going to explode is if you have an accumulation of fumes which should never happen when the fan is going.
    November 2007
Posted by modlvr on Friday, December 7, 2007 12:15 PM
Alliance on Thorium Brotherhood
    November 2007
Posted by modlvr on Friday, December 7, 2007 12:16 PM
I am using Acrylics. Doesn't that cut down on the fumes also?
    May 2005
Posted by Bgrigg on Friday, December 7, 2007 12:55 PM
There are fume you smell, and fumes you don't.
So long folks!
Posted by MikeV on Friday, December 7, 2007 1:46 PM
If you mean igniting then yes, unless you are using an airbrush cleaner that is flammable like 91% Iso alcohol.
