- Member since
Posted by ABARNE
on Friday, December 7, 2007 6:56 PM
You can use Testor's liquid cement (the brush on kind that comes in a bottle), and brush it on your plastic. Then after the surface has softened a bit, use a stiff brush (I use an old tooth brush) to stiple the surface. Depending on how much cement you use and your stipling technique, you can simulate castings of almost any roughness. The technique works great on 1/35 scale armor and would probably scale up fine to 1/12.
