HawkeyeHobbies wrote: |
I know Triarius will have something to add to this. |
Yep, eye of toad, wing of bat, and dried spider brains…
For Tamiya, approximately 50/50 is a good starting point, and you want to use 90% isopropyl alcohol or Tamiya thinner. It's a good idea to use an acrylic retarder if you use the alcohol. Tamiya thinner already has it.
For all paints, the best advice I've ever been given was "the consistency of 2% milk." This in conjunction with Gerald's TLAR principle will serve you well. It doesn't have to be scientifically precise. However, many beginners find it helpful to measure with a greater or lesser degree of precision, as it gives them more control—you know how much paint and reducer (the proper term for solvent used to reduce viscosity for spraying) you put in, so you always have a reference point. (Being an ex lab rat, I was and still am overly precise in my measurements, but my stopping point is TLAR. There is no substitute for practice and experience. You might want to practice on a paint hulk or a large sheet of scrap before trying it on a model. Don't practice on paper or cardboard, as they are absorbent and don't take paint like plastic does.
I always mix in a separate container, as that allows me to strain out any clumps or dried paint that may have gotten into the paint. The frustration of a clogged air brush and a ruined paint job are worth the extra step. I also find that it's easier to insure thorough mixing outside of the airbrush cup.
Experiment and find what works for you. YMMV.
