- Member since
Posted by ABARNE
on Tuesday, December 25, 2007 1:38 AM
semibold wrote: | is is safe to paint acrylic on top of enamal? |
As the others hae pointed out, it's perfectly safe. In fact there are some situations where it is even advantageous to do so because acrylics won't dissolve and lift enamels and vice versa. So if you're appliying a wash or even doing a lot of tedious brush painting, use a different type of paint than the base coat. If the base is enamel, wash with acrylic or use and enamel wash on an acrylic base.
