OMNI Matrix Air Cap compatible with Badger 360?
Posted by gmoalfaro on Saturday, December 29, 2007 3:03 PM
I previously own a Aztek, now a Badger 360 and a 100LG for fine art.
The only complain i have with the 360 it's that the point needle is unprotected compared to the crown regulator of 100 series.
The question is, can i use the Omni air cap guard (parts T8131G and T8131) with the 360? so i can replace parts 51-071 and 41-034, here a link with the parts in question http://www.tcpglobal.com/airbrushdepot/abtandcomniparts.aspx
https://www.webairbrushes.com/store/showproducts.cfm?categoryid=30&path=8%7CSpare%20Parts%7C30%7CModel%20155%20%26%20360%20Spare%20Parts%20%7C
The T8131G Omni air cap guard, protects the point needle. All ready damage a needle when accidentally i drop the airbrush and was without the protective cap.
Thanks for your help
Posted by MikeV on Saturday, December 29, 2007 5:02 PM
No you cannot as they are different threads.
When not in use you should put the protective head cover on the 360 so that the needle is not damaged if you happen to drop it.
I have never in my 14-15 years of airbrushing, dropped an airbrush accidentally. Maybe you should look into a solid holder for your airbrush such as the one Badger sells that I use.
Posted by gmoalfaro on Monday, December 31, 2007 12:30 AM
Thanks Mike, Ken all ready answer me and the part i need is 41-043.
I drop it when i was cleaning the cup, it slide from the paper towel soaked in thinner i was using to clean it, sorry to disturb you.
I have Universal Airbrush Cleaning Station and Bear Claw Airbrush Holder (picture below)
