Flying Tigers' Colors
    January 2008
Posted by bkjohns96 on Tuesday, January 1, 2008 9:58 PM
I'm painting some very small scale P-40's. I have good pics of the camo scheme, but the colors are hard to tell. What colors did they use on the uppers and lowers? Any help appreciated.
A million thanks,
    September 2012
Posted by namrednef on Tuesday, January 1, 2008 11:06 PM
"Very small scale".....leaves a lot of room for interpretation....if tiny, I would say....use an olive drab upper and light grey lower.....but lighten the green......the smaller the subject....the darker the paint will look.
For help......go to the 'Aircraft' topics and click on anything mentioning a 'giant penny'
Nam
jwb
    February 2006
Posted by jwb on Wednesday, January 2, 2008 6:06 PM
For the AVG birds, the upper surfaces on the P-40Bs were British Dark Earth and British Dark Green, with undersurfaces a shade of gray somewhat lighter than the US neutral gray.
If you're building an AVG "E" model, the pics I've seen had them as OD over neutral gray, though some may have been the Dark Green/Dark Earth scheme. I've not seen any pics of those, but several folks have said they've seen that.
The debate over scale effect is an old one with opinions either way. To my eye, lightening up colors a bit on smaller aircraft does appear to look better, but if you use various pre-shading and weathering techniques to vary the  colors, it'll accomplish the same thing.
Jon Bius
AgapeModels.com- Modeling with a Higher purpose
"For I know the plans I have for you," declares the Lord, "plans to prosper you and not to harm you, plans to give you hope and a future." ~ Jeremiah 29:11
    May 2004
My understanding of "Flying Tiger" colors
Posted by cbaltrin on Monday, January 7, 2008 6:37 PM
Most US Aicraft came out of the factory cammoflaged with Olive Drab upper surfaces and Neutral Grey undersides (medium gray?). If there is a two tone upper camoflage (brown /green for instance) than, it is likely just the factory scheme with some RAF brown sprayed on top (some version of RAF Earth I imagine). Hope that helps.
On the Bench: Too Much
