using masks
    September 2007
using masks
Posted by not enough time for modeling on Wednesday, January 2, 2008 7:33 PM
I will be using masks for the first time on the canopy of the Dornier Do335, both film and liquid. Any tips, suggestions,etc I should be aware of? How do I clean the canopies before airbrushing without damaging or disturbing the masks?
   After this project I will attempt the 1/72 scale Blohm & Voss BV 141. (I'm into ugly aircraft lately).
    February 2006
Posted by Wulf on Wednesday, January 2, 2008 8:10 PM
What type of masks are you using? Pre-cut masks? If they are the pre-cut masks, you will be spoiled! They are quick and easy. Can't go wrong with them.
Best thing to do is clean the canopy before you mask it and you won't have to do it later. But if you do, just a swab with a little alcohol should do the trick. It won't bother the mask. Don't get it on the liquid mask though. Work around it.
Andy
    September 2007
Posted by not enough time for modeling on Wednesday, January 2, 2008 8:17 PM
I got the precut masks. Its funny that it still requires liquid masking on some areas.  Some of the precut panels will need to be trimmed too.
I thought alcohol might clean the canopies but I was afraid it may dissolve the masks.
Thanks for the info.
    February 2006
Posted by Wulf on Wednesday, January 2, 2008 8:24 PM
Yeah, I've had to use liquid mask on occasion as well for those compound curves that masks can't cover. No sweat though, it's still the way to go. You may have to trim the masks too. Better too big than not big enough. Just use a NEW xacto blade when trimming. Like I said, you will be spoiled. And the cool thing is, they offer a lot of masks for many kits. I use them for every kit I do if available.
Andy
    May 2004
Beware of Liquid Masks
Posted by cbaltrin on Monday, January 7, 2008 6:33 PM
I have never had success with these. The problem is they alway stretch before they come off and, as a result, cause the paint to tear, flake, crumble or otherwise leave an unacceptable looking edge...
On the Bench: Too Much
    August 2005
Posted by Phil_H on Monday, January 7, 2008 7:23 PM
3 ways to minimise this:
  • Remove the mask when the paint has dried, but not fully hardened
  • Run the tip of your knife lightly around the edge of the mask to score a "break line" in the paint before removing the mask.
  • When removing the mask, pull it back over itself at a sharp angle - don't pull it straight up.
