TAMIYA LIQUID PRIMER = with airbrushing, do you thin or not?
    October 2007
Posted by buman on Tuesday, January 8, 2008 10:30 AM
Hi everyone, I am new at this (airbrushing) so please forgive me...
I am about to use an airbrush for the very first time:
a) Do you thin your TAMIYA Liquid Primer? (which I have)
b) If you DO thin the Tamiya Primer 1) what is a good ratio? 2) CAN you use the Tamiya Thinner ? (which I have and use in order to thin my TAMIYA paint)
Thank you so much for any advice and help.
Oliver
    August 2005
Posted by Phil_H on Tuesday, January 8, 2008 5:38 PM
If you're talking about Tamiya's "Liquid Surface Primer" in the 40ml jars, I haven't airbrushed it, but "in the jar", it is too thick to airbrush without thinning.
The description on the Tamiya USA website says: Can be further diluted using Tamiya Lacquer Thinner, allowing it to be used in airbrushes. I believe Tamiya acrylic thinner (X-20A, if that's what you have) will more than likely be incompatible. (Having said that, I am able to clean my brushes with ethanol after using LSP)
    October 2007
Posted by buman on Wednesday, January 9, 2008 6:34 AM
 Thank you so much - I didn't know Tamiya has a Lacquer Thinner. I am going to give it a try. I also wonder if a regular Paint Thinner (from Lowes, HomeDepot etc) would work (as it works well with Testor Enamel Paint).
 Oliver
