Priming models
    July 2003
Priming models
Posted by MonsterZero on Wednesday, February 6, 2008 6:46 PM
Is there anything wrong with using ordinary flat white enamel/acrylic as the primer? I know certain modelers use special primers but so far I tried only the Testors primer in a can. This has produced one of the roughest and ugliest finishes I have ever see because the can failed to atomize the primer like an airbrush does.
    January 2003
Posted by Triarius on Wednesday, February 6, 2008 7:21 PM
I use one of Tamiya's flat light gray acrylics as a primer, although I may switch to Polly Scale when I've used up my current stock (nothing wrong with the Tamiya, but I really like Polly Scale.)
For a primer, you want a light, thin coat with good adhesion. Tamiya and Polly Scale have the best adhesion of any non metallic acrylic paints I've ever seen, heard, or smelt. (No, not the little fishies! Laugh [(-D]) If you do go with an acrylic, make sure the plastic surface is very clean—no, cleaner than that. Wink [;)]
Just don't use a gloss.
Posted by rjkplasticmod on Wednesday, February 6, 2008 7:40 PM
I use Floquil Grey Primer.  It's an enamel & the best primer I've found for modeling.  Must be applied with an AB.
Regards,  Rick
    January 2008
Posted by PleoMax on Wednesday, February 6, 2008 8:04 PM
I always had problems with spray cans and I would never use them again. I use MM's Grey Primer (enamel) thru airbrush and it's very good.
    August 2005
Posted by EdGrune on Wednesday, February 6, 2008 9:04 PM
I have had nothing but problems with the MM Gray Primer.  I threw it away.
On the other hand spray cans are great!  Be sure to check the big box stores for the jumbo-economy sized ones.
Krylon,  Plasticote, Rustoleum, American Painter - all make excellent primers.   They cost less than the ones with the model manufacturer's logo.   Be sure that the cans are room temperature or warmer and agitated well before use   Spray light mist coats instead of a single gloppy coat.
[Oh, and by the way, did you know that Model Master paint is manufactured by RPM Industries, the same people who bring you Rustoleum?]
And to the original question -- there is no problem in airbrushing a light coat of flat white as a primer.  Be sure that it is properly thinned and spray light coats.
Experiment and find what works best for you.   There is no one-size-fits-all.
    January 2008
Posted by PleoMax on Wednesday, February 6, 2008 10:43 PM
If you don't have experience with spray cans, I would suggest you to avoid them as they are more complicated...temperature, humidity, distance, thickness, volume, etc. They also can obliterate the surface details quickly if you don't move them fast enough and it's not fun to try and fix.
Good luck.
    January 2007
Posted by dahut on Wednesday, February 6, 2008 11:04 PM
I've used good flat white from a rattle can for years. Not the cheap stuff but Krylon and that ilk.
You should also heat the paint in hot tap water prior to painting and apply thin coats - never single, heavy ones. Then finish up with micro mesh sanding and/or polishing with a T-shirt prior to color coats.
All that being said, these paints have a large grain to the solids and there is little can be done about it. I wouldn't use them below 1/48 scale. In that scale I suggest Floquil metallics, airbrushed of course.
In the end it would probably be best to just airbrush the Floquil primers and metallics all the time and just stick with them. A the cost of some of the dedicated rattle can modeling primers (Mr Surfacer: $5-10), it seems a good idea. Dont have an airbrush? Time to take the plunge...
Cheers, David
Posted by MikeV on Thursday, February 7, 2008 1:49 AM
Regards,  Rick
Sign - Ditto [#ditto] I would like to find a good acrylic though so I don't have to smell lacquer thinner when I clean the airbrush.
    January 2007
Posted by Gigatron on Thursday, February 7, 2008 8:13 AM
For large surface areas, without a lot of intricate detail, I use krylon primer in the big spray can.  Decent coverage (use light, misted coats) and is really inexpensive.
For small pieces with a lot of detail, i.e. cockpits, wheelwells, etc., I use floquil lt. grey undercoating.  It's thinner than spray can stuff, sprays and brushes well, but ounce for ounce is much more expensive.
-Fred
    May 2004
Posted by cbaltrin on Thursday, February 7, 2008 10:58 AM
Mr.Surfacer 1000 thinner with Mr.Color thinner works superbly as a primer. That is what I usually use. Even works well as a base coat for Alclad II
On the Bench: Too Much
    March 2008
Posted by jtan163 on Thursday, March 20, 2008 11:53 PM
I have a jar of Mr Surfacer 1000, which I intended to put through my AB.
However when I did it came out sringy.
Can any help me with this?
Do I need to thin it? If yes, what with?
If no, then what?
    September 2005
Posted by nathaniel on Monday, March 24, 2008 2:53 AM
You definitely need to thin it.  Mr. Color makes a thinner, but any lacquer thinner will work, provided it's not too "hot" to melt plastic.
If it's still coming out stringy, thin a bit more and turn down the pressure on your airbrush.
    August 2007
Posted by doc-hm3 on Monday, March 24, 2008 8:55 AM
You might consider Dupont 30S automotive(laquer)primer. At 34.00qt USD, it sounds expensive until you figure the cost of all those little bottles to make a quart. A gallon of laquer thinner, automotive grade will run about 10.00USD
All gave some and some gave all.
    March 2008
Posted by Killjoy on Saturday, March 29, 2008 11:39 AM
I have been painting various models and figurines by hand for 10 years + now, and didn't get into airbrushing until 1 1/2 years ago, so my knowledge base is mainly from doing up 28 mm figurines and vehicles, but I have tried many kinds of rattle can primer, and found the best to be Games Workshop.  They make it in balck or white, it sprays consistantly, and doesn't have large clumps or texture.
Haven't tried airbrushing primer yet, I'll have to give it a shot.  We have a RR store just down the block which sells Polyscale, I will pick up their flat grey and shoot it onto something!
Chris
A veteran is someone who, at one point in their life, wrote a blank check made payable to "The United States of America," for an amount of "up to and including my life."
