Why cut out in airbrush handle?
Posted by gjek on Tuesday, February 12, 2008 1:08 AM
I use an Iwata and the preset handle has a cutout to expose the needle locking nut. What is the advantage to this? I have never had a "need" for this feature that I am aware of. Thanks.
Msgt USMC Ret M48, M60A1, M1A1
Posted by MikeV on Tuesday, February 12, 2008 2:04 AM
Those were designed originally for T-shirt artists so that when the tip plugged with paint you could grab the needle locking nut and turn it and loosen the needle to clear the clog.
You can also pull the trigger all the way back and then grab that locking nut and pull it back even further for blasting paint out of the tip or getting the most paint possible coming out of the airbrush.
    August 2006
Posted by HawkeyeHobbies on Tuesday, February 12, 2008 10:47 AM
I too wondered this...I finally found out after I read the instructions and the tips section on their website.
Gerald "Hawkeye" Voigt
    January 2004
Posted by kenbadger on Tuesday, February 12, 2008 7:27 PM
On the Badger Anthem 155, Universal 360, and SOTAR 2020 - the cut away handle is part of the patented design that allows for easy needle access and removal from the rear of the airbrush for fast and easy tip dry cleaning and removal.
Take air, Ken @ Badger
Mark 10:27
kenbadger@aol.com
AMERICAN MADE AIRBRUSH EXCELLENCE
www.badgerairbrush.com
    May 2005
Posted by Bgrigg on Tuesday, February 12, 2008 8:39 PM
Off topic but...
Ken, it's great that you have joined the forums. I wish more manufacturers and distributors would join as it certainly helps the prevention of misinformation being repeated. Mike and I will have to be on our toes!
So long folks!
Posted by gjek on Wednesday, February 13, 2008 12:12 AM
OK so I'm slow... but to use it I would loosen the nut then try to back out the needle,fiddle with it, ease it back and retighten it all through the small slot in the handle. It has always been easier (to me) to just unscrew the handle where you have more room to work the needle. If I am having that much of an issue I would just paint without the handle so I could quickly work the needle. I also like the working feel of the handle without the cut out.
Posted by Wingman_kz on Wednesday, February 13, 2008 9:05 AM
I believe you can get a replacement handle without the cutout. Or, you can check the link below. It's what they call their Triple Action handle that preserves the preset feature but has no cutuot and incorporates a quick release for the needle. If you look under Products on the site you can buy this kit with either a single, silver handle or with an assortment of 5 different anodized colors.
http://www.iwata-medea.com/resources/triple_action.jsp
If you don't mind me asking, how do you like the preset feature? I don't know which model you have but does your's have the MAC valve to fine tune air pressure? If it does, how do you like that?
Tony
Posted by gjek on Wednesday, February 13, 2008 5:39 PM
I am currently using an HP-C an a detail brush. I like the preset option. If I am working on something tedious I am not worried about too much paint As I start and stop. It also alows for very consistant paint flow. If I choose not to use the feature I simply back off the screw and it is a straight double action. I don't have the mac valve option so I can't be of much help there.  Greg.
    October 2007
Posted by sizzlak on Wednesday, February 13, 2008 10:10 PM
It's used to clear clogs by pulling back on the locking nut and blowing air without having to remove the handle.
