Brian D. wrote: |
Jesse, I was under the impression that you had to mix the Tamiya Clear with the Tamiya paint in order to get the proper finish. |
You may be confusing this with mixing Tamiya clear gloss (X-22) (or Future) with Tamiya Flat Base (X-21) to make a clear flat coat, as Tamiya does not make a flat clear coat "in the bottle".
Similarly, the Flat Base may be mixed with gloss colors to make them "flat".
