primer
    February 2008
primer
Posted by baddley on Saturday, March 8, 2008 9:48 PM
hello
how many coats of primer do you guys normally spray generally
also will freezer tape work for masking. i have seen freezer tape fot really cheap. does the blue tape work good for straight line stuff.
thanks scott
    April 2014
Posted by Carves on Sunday, March 9, 2008 11:13 AM
If you are just priming plastic, I normally just do it once as long as all surface are all evenly covered.
For PE and resin surface, I do it twice just incase.
Ben
    February 2006
Posted by Wulf on Sunday, March 9, 2008 1:25 PM
I'm not sure about freezer tape. I never used the stuff. If it is a low tac tape, it should work. However, The 3M blue painters tape works great. Make sure it is the "delicate surface" type. I use this kind exclusively.
Andy
Posted by ABARNE on Sunday, March 9, 2008 4:14 PM
I don't normally prime anything.  If have a situation in which I have a lot of putty or light colored scratch-built plastic parts on a dark plastic model, I might spray a coat of gray to help even out the colors before going with my actual color coat.
When I was kid, I used freezer tape because it was available, but it is not the best stuff to use.  3M Blue tape does a much better job at making clean lines and being lower-tack is a lot less likely to pull up underlying paint.  Even better is Tamiya's Yellow Tape.  It's a bit pricier, but it gives really clean lines, is flexible enough to conform to compound curves, and is low tack so it doesn't pull up the underlying paint.
Andy
