Pre-shading only works if you don't paint it all out. The idea is to give depth to panel lines. Many people (myself included) just use a sludge wash after the painting is done for the same effect without all the work.
Clear coats come in two basic kinds: glossy and flat. There are more variations than that (semi-gloss, satin, etc.) but those are the main two. Typically you gloss clear coat a flat paint job so decals won't silver (air gets under the decal as flat paint isn't actually FLAT), then once the decals are snugged down another clear coat, this time flat, brings it back to the "proper" finish.
