I have a Badger 360 that I am soon going to use for the first time and will use it with a Badger Cyclone compressor. Since I am new to airbrushes and such, should I invest in a filter or moisture trap or both?
Badger makes a combination filter/regulator/trap (BAD50054) that sells for ~$90CAN and also makes just a moisture trap (BAD50051) that sells for ~$60CAN. Anyone have any experience with these and if so, what do you recommend? I like the idea of regulating the airflow but want to ensure if I buy the BAD50054 it will also trap moisture/dirt.
I look forward to your comments!
RODC
