crkrieser
Don -
You refer to Epson inks. What's been your experience with HP inks?
Curt
Curt:
If you'll excuse me butting in unasked, I've done a lot of decal work with HP printers, so I'll share my experience for what it's worth.
The first HP printer I tried was an old HP 722C, and I could never get relly good results with it. Useable---but not good. No matter what printer settings I tried (and I tried them all), no matter what decal paper and sealer combination I used, the ink would bead up on the paper, or run and bleed after it was sealed (sometimes weeks after, literally). Black was the least-bad to use, colors would never really get any saturation, and any red at all would 'blush' around the edges.
My current printer, an HP F4280, is exactly the opposite. It worked well from the first time I used it, pretty much regardless of the settings. I use Bare Metal's Experts Choice paper most often (because it's most economical---though I've used several others with no complaints as well), and Testors Decal Bonder spray to seal. (I have also used Krylon acrylic, Tamiya Clear and Micro Decal Film with good results).
I always assumed the first printer's problem was formulation of the inks for the required cartridge, though that's just a guess. I could never find any good information on ink formulations, so maybe it's proprietary by manufacturer.
Hope it helps.
