decals with future
    November 2004
decals with future
Posted by gumshoe59 on Tuesday, October 16, 2018 5:47 PM
Put a decal on over future with micro set and future turned white. if i remembe, just put on more future and the white will go away. is that right or shoilfd I do something else?
Thanks,John
    July 2004
Posted by stikpusher on Tuesday, October 16, 2018 8:39 PM
Yes, more Future should clean up any white fogging on the model surface.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    September 2012
Posted by GMorrison on Tuesday, October 16, 2018 8:40 PM
Well I don't share the optimism of my friend, but it can't hurt to try.
I've had that happen too, one of the reasons why I try not to use Micro Sol, Set etc. unless really necessary.
    July 2004
Posted by stikpusher on Wednesday, October 17, 2018 12:54 PM
It worked for me here. Although the culprit was Solvaset, not Microset.
       - Plankton
LSM
    November 2008
Posted by plasticjunkie on Friday, October 19, 2018 12:17 PM
That happens when the Future is not fully cured. I let it sit for at least 2 days before using any decal solution. Applying more Future works most of the times at getting rid of the reaction. It happened to me once and it didn’t work so I had to lightly sand and repaint the area.
 GIFMaker.org_jy_Ayj_O
    July 2004
Posted by stikpusher on Friday, October 19, 2018 4:39 PM
I usually let Future cure a day or longer. This was 7 years ago or so, so I don’t remember. And it was Solvaset, which is far “hotter” than Microset. You can let Future cure for a week or more and still get this with Solvaset.
       - Plankton
LSM
    November 2008
Posted by plasticjunkie on Friday, October 19, 2018 5:12 PM
Stik
I strictly use Solvaset and have never had a problem if the Future cures for at least 2 days.
My issue was that I used Solvaset like 10 hours after applying the Future. It looked like a white haze around the decal.
