Frankly, I think the detail relief is way outta scale... I'd sand it almost flush and then apply the decal... With heavy relief and no decals, I usually shoot the panels in flat white enamel, fairly heavily, but in two or three light coats, letting it dry in between coats, but not so much as to fill in the relief. Then hit it with black Sharpie, then a few swipes with super-fine sandpaper to remove the black from the relief and let the white show through.. Revell 1/32 Spitfire Panel: You know Hans I've tried that very thing once, looked like crap maybe I did'nt use enough white or I was too impatiant and scraped too early, never the less your spit panel shows me its a trick I should revisit. Thanks |
