Painting a decal letter to get a different color
    January 2003
Posted by stinger on Sunday, December 7, 2003 9:26 AM
Hi all - I need a white "H" code letter for the fuselage on my Do17z. All I have on my decal sheet are black ones, and I can't find any on the net.
1. Can I cut out the black one, paint it white, and then apply it to a curved surface without the paint cracking?
2. What paint should I use? The best white I have with decent opacity is Floquil's reefer white. Would that work? Should I overcoat it with a clear before applying it?
Does any one know of a decal sheet of white German code letters, 1/72 scale?
Thanks for any help you can give.
Stinger
May an Angel be your wingman, and the Sun be always at your six
Posted by Jeeves on Sunday, December 7, 2003 9:50 AM
1. While it may not work for everyone-- I had to change the blue/white checkerboard scheme on a decal to blue and black....being too lazy to mask all those diamonds, I just painted in the black....and it worked great for me.
2. I used regular ModelMaster Gloss Black acrylic for my decal...let it dry a couple days- and it went onto the nose very smoothly-- especially with some MicroSet and Sol.
Posted by Anonymous on Sunday, December 7, 2003 12:22 PM
I've painted large decals then cut them in to strips to put on greenhouse style canopies like the He 111 and bomber turrets without any problems.
    January 2003
Posted by stinger on Monday, December 8, 2003 12:38 PM
Thanks guys - I'll give it a try. After all, it is a pretty simple letter make.
Stinger
Posted by wibhi2 on Tuesday, December 16, 2003 8:27 AM
You could also paint a white area, apply the black decal over the white area (dry transfer work best for this method, tho) - paint your camo. After it's dry, take a piece of tape and dap the decal with the sticky side to remove it.
3d modelling is an option a true mental excercise in frusrtation
    January 2003
Posted by stinger on Tuesday, December 16, 2003 5:48 PM
Good idea wibhi2. I'll consider that option also.
Thanks
Stinger
Posted by dubix88 on Wednesday, December 17, 2003 1:59 PM
HEY,
That is a good idea wibhi2.I was thinking of somethig like that but couldnt think of anything to use for the H and you solved that.
Randy
THATS MY VOTE "If a woman has to choose between catching a fly ball and saving infant's life, she will choose to save the infant's life without even considering if there is a man on base." -Dave Barry In the words of the great Larry the Cable Guy, "GIT-R-DONE!!!"
    September 2003
Posted by checkmateking02 on Thursday, December 18, 2003 8:15 PM
Here's what I've done: use a straight edge and x-acto blade to lightly cut through the decal (not all the way through the backing paper, though). Then paint the decal, let the paint dry a couple of hours and apply as normal. I've done this successfully to change yellow 8th AAF codes to the proper gray. Usually I do the decaling as soon as possible after painting the decal, so that the paint stays somewhat flexible. I don't know if the paint would crack if left to dry too long. I've used Model Master for this, thinned with DioSol and Glaze, both Floquil products, so I think the technique would work using Floquil paint, too.
Posted by wibhi2 on Sunday, December 28, 2003 9:52 PM
Thanks guys, I remembered that one from an old Kalambach/FSM publication and have used it a few times with great success.Whistling [:-^]
    January 2003
Posted by stinger on Monday, December 29, 2003 1:10 PM
Where is a good source for dry transfers? Can you get national insignias, such as swastikas and german crosses in dry transfer also?
Thanks for all the tips.
stinger
Posted by wibhi2 on Wednesday, December 31, 2003 9:56 AM
First, try Verliden or Squadron. If you live near a graphic art supply store you can get the Letraset dry transfers. They come in a multitude of font styles and sizes.
    January 2003
Posted by stinger on Wednesday, December 31, 2003 3:54 PM
Thanks wibhi2 - I'll check that out.
In the meantime I've been experimenting with painting clear decal film. Biggest problem is finding a knife sharp enough to not tear the film. Even a brand new #11 won't cut into or out of corners with the crispness I want, although for a simple "H" letter I can just lay it down in strips.
Will let you know how it turns out.
Thanks again, stinger
