Amount of time to soak decal in water?
    November 2008
Posted by Arespontus on Sunday, November 22, 2009 10:54 PM
Hi
I am about to apply the decals to my 1/72 Warthog.
What is the optimum amount of time to soak the decal in water and should I use warm, hot or cold water.
I've had problems in the past where the decals tear apart.
thanks
Scott
    July 2009
Posted by COLDIRON on Sunday, November 22, 2009 11:11 PM
Usually about 30-60 seconds for warm water.  Then just use your finger and see if the decal moves side to side on the paper, once it can slide, apply.
    May 2003
Posted by kirk4010 on Sunday, November 22, 2009 11:18 PM
I find 20 sec. is enough time.  The key is that the water is warm.
The art of war is simple enough. Find out where your enemy is. Get at him as soon as you can. Strike him as hard as you can, and keep moving.-Ulysses S. Grant
    August 2005
Posted by Phil_H on Sunday, November 22, 2009 11:43 PM
It's preferable not to leave it soaking in a dish of water. Dip it, but take it out and leave it sitting on a hard surface to allow it to absorb the water it has picked up. This minimises glue loss and avoids the decal floating free of the backing paper if left in water too long. Yes, you want it to come off the paper, but not at the bottom of a dish of water.
If you watch carefully as it's soaking, you will see the paper changing from white to semi-translucent as the water displaces air in the paper. When this reaches a uniform shade, the decal will usually release. If not, wait about 10 seconds and try again.
Note that if there are any spots of glue or paint on the back of the paper, the water will not soak through and the corresponding part of a decal on the other side will not release.
    June 2009
Posted by jimbot58 on Monday, November 23, 2009 3:35 AM
I usually dip for 20-30 seconds, then lay it on a folded paper towel to absorb exxess water. When it begins to slide after several minutes, it's ready to apply. That way, I am using the setting solution I applied to my surface to "float" the decal into place and not the tap water..
On my workbench now:
It's all about classic cars now!
Why can't I find the "Any" key on my keyboard?
