B-24 Diamond Lil
B-24 Diamond Lil
Posted by woody0369 on Thursday, December 3, 2009 5:31 PM
I'm just starting a 1/48th B-24 and I want to represent the CAF B-24 "Diamond Lil".  Anyone know if there are decals for this plane or am gonna have to improvise?  If they do exsist, where can I get them?
 Thanks a ton
    June 2008
Posted by Hans von Hammer on Friday, December 4, 2009 10:53 AM
I was in the CAF B-29/B-24 Squadron before I mooved to Iowa... Far as I know, you'll have to make 'em... Don't forget that Lil wasn't a B-24 either... It's an LB-30 with a "D" nose... You'll need four of the Monogram PBY engines & cowls...  It's since been restored to it's original B-24A configuration, with turrets and is now "Ol' 927"
    September 2006
Posted by the Baron on Friday, December 4, 2009 11:47 AM
 Hans von Hammer wrote:
...Don't forget that Lil wasn't a B-24 either... It's an LB-30 with a "D" nose... You'll need four of the Monogram PBY engines & cowls...
May I add, he'll need to do some surgery on the engine nacelles, too, since they're cast for the horizontal ellipticals for the vented nacelles in the kit.  The LB-30's (and the -40, too) cowlings are round, so the area where the nacelles meet the leading edge of the wing is narrower.
I'm facing the same surgery; I want to model General Tinker's LB-30, lost on 7. June in the aftermath of the Battle of Midway.  He wanted to strike at Wake from Midway, and led a four-plane formation, but his Liberator crashed not long after takeoff and presumably as a result of a technical failure.  Anyway, I've got the Monogram B-24D as a starting point, and I'll have to replace the engines, cowlings and nacelles.
A long-range, long-term project...
