decal solutions used?
    August 2008
Posted by pathvet9 on Tuesday, February 2, 2010 1:35 PM
I have been using the kit solutions from MicroMark and have not seemed totally happy, especially with the softening solution.
Am I correct in my smeller    Stick out tongue          that the setting solution is nothing more than white vinegar?
What is in the softening solution and what brands do people favor the most, as well as economically? The MicroMark jars seem pretty measly.   Whistling
Cheers, Jake
Nuts to all but my Norfolk terrier is laughing
    July 2014
Posted by batai37 on Tuesday, February 2, 2010 3:04 PM
Some people in fact use straight white vinegar, as it is essentially the same thing. A lot cheaper too. The only commercial products I'm familiar with are the MicroScale and MicroMark systems. I use Micro Set and Micro Sol myself.
How are you using the softening solution? Lots of people who report unsatisfactory results with decal softeners, e.g. wrinkling, are applying it before the wet decal has had a chance to set and dry (including me).
Through some trial and error, as well as according to advice I've found on this forum, I've found Micro Sol works best when the decal is totally dry, and then let the softening solution do it's work overnight. If there are still wrinkles or bubbles, you can carefully puncture the area with a needle or sharp X-Acto and then reapply.
    October 2007
Posted by Milairjunkie on Tuesday, February 2, 2010 4:21 PM
I am also using Sol & Set, but cant really say I am to impressed in the Sol.
    March 2006
Posted by daiguma on Saturday, February 13, 2010 3:05 PM
Polly Scale setting and softening solutions. The best I have ever used. Found them in a model railroad shop.
"Live life to the fullest and die without regrets"
