disintagrating decals
    April 2011
Posted by nite halk on Saturday, June 18, 2011 2:40 PM
 I am trying to put the decals on my Gloster and the decals kepp falling part.They won't slide and don't stay to gether.  ANY Ideas
I have tried a couple things,differant water temp, longer in the water,shorter time in thte water,nothing sweems to work.I have been useing the ones that don't go on this version..
    April 2004
Posted by Jon_a_its on Saturday, June 18, 2011 2:50 PM
give them a coat of future, allow to dry then cut round the decal closely before soaking to remove backing.
Microscale do a " Liquid decal film " #MI-12 that much the same thing.
East Mids Model Club 32nd Annual Show 2nd April 2023
 http://www.eastmidsmodelclub.co.uk/
Don't feed the CM!
    April 2011
Posted by nite halk on Saturday, June 18, 2011 4:13 PM
Thanks I will go try it now
    April 2011
Posted by nite halk on Saturday, June 18, 2011 9:58 PM
       Still not working
    August 2005
Posted by Phil_H on Saturday, June 18, 2011 10:50 PM
I highly recommend Microscale's Liquid Decal Film. Good insurance for old decals.
AT6
    December 2005
Posted by AT6 on Friday, June 24, 2011 5:34 AM
Another method is to spray the sheet with Microgloss and cut close to the decal after the gloss has properly dried. Thats the way friends taught me how to salvage older decals or decals that have numerous problems. H ope this works for you.
    April 2011
Posted by nite halk on Tuesday, July 19, 2011 10:23 AM
 I have tried the decal set,to no availe.But looking at the plane,it has see acrylic cowlings for the engines,and with the work put into them I am thinking of repainting it like a civiian aircraft,so it won't look to out of sorts with the see through engine cowlings,what do you all think??
Posted by Don Stauffer on Tuesday, July 19, 2011 10:27 AM
nite halk
Decal set will make problem worse.  As someone said, you need the liquid decal film stuff.  Future is a cheap replacement, but not as good.
