Inkjet Printing Decals
    July 2011
Posted by Mindenroses on Sunday, August 7, 2011 6:23 AM
Hello, All:
Can anyone either provide tips for using an inkjet printer to print decals or point me to an article, tips or posts on this site that cover the topic.  I have the FSM back issue that deals with the mythic ALPS printer, but I'm using an HP Photosmart.  I'm particularly interested in techniques to seal the decal after printing on decal stock, but before applying to the kit.  Many thanks in advance for all advice!
    October 2008
Posted by bsyamato on Sunday, August 7, 2011 6:29 AM
i just leave 2 days to dry after printed, then put on the decals a layer of micro or superfilm liquid to seal it, i use a brush, but an airbrush is better. ps don't thin the superfilm liquid.
After seal liquid is dry just use as normal decals.
Posted by gregbale on Sunday, August 7, 2011 8:51 AM
I've had better luck airbrush spraying a clear coat (I've used Tamiya clear gloss acrylic and Testors matte acrylic with good results, but keep the coats thin). I've also used a number of rattle-can clear coats like Krylon acrylic--the actual stuff works fine (i.e., doesn't bleed or run the ink), but it's tricky to keep little bubbles from appearing, and they seem resistant to popping.
I've tried brushing on Micro decal film, and have had problems with reds leaching out and "blushing" slightly. (I've got an HP F4200 printer, and use Bare Metal Foil's Experts Choice paper.)
Greg
George Lewis:
    October 2008
Posted by bsyamato on Sunday, August 7, 2011 1:26 PM
i used too bare metal foils etc, probably micro film was old ( as mine Whistling ) or the red just not dried .
never used the glossy as seal decals, microfilm fix as a sort of rubber film on decals.
black colors work perfectly
reds colors tend to desaturete with clear decals base
my only try on a plane was on the academy corsair with white color decal sheets
    September 2003
Posted by checkmateking02 on Sunday, August 7, 2011 2:07 PM
Thanks for the information, also.  I was planning on trying this too, for some noseart decals that aren't available commercially.
Does the brand of decal sheet make any/much difference?  I have a white sheet from Tauro, the only kind I could find at the time.
Posted by gregbale on Sunday, August 7, 2011 2:24 PM
I'm not familiar with Tauro's line, but if it's a plain white decal sheet, it might not work. I've tried printing on MicroScale's plain white stock with terrible results--ink either beaded up instantly, or bled horribly with the clear coat even after an overly-cautious drying period (which I'm prone to allow for, anyway).
Since most sheets designed for printing decals on a home printer specify either inkjet or laser printer only, I'm assuming there's some sort of special coating involved to take and hold the given variety of ink.
My best advice would be to practice with small pieces of the decal you've got and see how it works out...but you might need something else.
Best of luck.
Greg
George Lewis:
    September 2003
Posted by checkmateking02 on Sunday, August 7, 2011 2:43 PM
Thank you for the quick reply!
I think you might be right about plain white decal sheets; they are pretty slick and smooth without much "traction" for the ink to grab onto.  Beading up is a distinct possibility.
I will give it a try, anyhow; and then maybe check around for inkjet friendly decal paper.  Maybe someplace like a craftstore might even stock them.  I was looking around back in January, and at that time no one seemed to have any, except Hannant's in London, where I got mine.
I see Tower Hobbies has a brand of Testor's decal sheets, for a decal printing system, to work with inkjets.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXESK4&P=V
Maybe someone has experience or knowledge of this?  It sounds great if it would work.
Posted by gregbale on Sunday, August 7, 2011 6:13 PM
I've never used Testors decal paper (although I recently picked up a pack to experiment with, just haven't had a chance to try it yet). If you find yourself looking for other options, the "Experts Choice" brand is available directly from BareMetal's website:
http://www.bare-metal.com/Experts-Choice-Decal-Film.html
Scalehobbyist.com also usually has it in stock, at a slightly lower price:
http://www.scalehobbyist.com/catagories/browse.php?pg=1&ppp=24&sb=stocknumber&so=a&kw=film&man=BMF
I have no affiliation whatsoever with either company, but I've had good, consistent results with the product.
Cheers
Greg
George Lewis:
Posted by Don Stauffer on Monday, August 8, 2011 9:25 AM
I'm partial to the stuff sold by Micro Mark.  You can get both white and clear,  in both inkjet and laser print.  The stuff is good decal paper and always had good order service from Micro Mark.
I have printed with both Epson and Canon printers, never tried HP, but I'll bet there is not much difference between major brands of inkjet printers.
Printing dark decals is easy- use the clear sheet. Light colored decals must be applied to the white paper (inkjet printers print light colors very lightly- the ink design is not very opaque).  Using white paper means you either need to trim all decals perfectly, or match the background color of your artwork very closely with the background paint color.  The later step is difficult if you (like me) have not color calibrated your computer setup.  Decals are not bad on black- matching black is pretty easy- but for other backgrounds it is more of a challenge.
    June 2008
Posted by Hans von Hammer on Tuesday, August 9, 2011 11:51 PM
I use Testor's decal paper, and Testor's Decal Bonder.... Had pretty good results with both...
    April 2011
Posted by Aeros on Wednesday, August 10, 2011 1:15 AM
I found out that the best results for laying down decals over a dark area is to mask the area and paint it white. Even though the decal paper is white, it still not opaque enough to stop the color underneath from bleeding through. Or if the size of the decal can be handled without it folding over itself, then try cutting out a blank and place the printed piece over it.
Posted by Don Stauffer on Friday, August 12, 2011 7:54 AM
Aeros
Aeros
This can work for simple shapes, but is hard for white lettering or complex shapes.,
