Chris:
It's a lot easier to cut a piece of decal sheet to the size you need. I usually print out my design on a plain sheet of paper to get the size and location needed, then lightly tape an appropriately-sized section of decal paper over that design and run it through again to make the decal. Saves a bunch on wasted sheet.
One tip---tape all four sides of the section of decal paper. That way the printer head will pass over it smoothly and print without catching or hanging up.
Good luck.
Greg
George Lewis:
I've run an ever smaller length of decal paper through an inkjet printer several times. Have to watch out for places that can snag. Greg's suggestion of cutting out the size you need and taping it to the test paper sheet sounds like a good one.
Paul
I run the paper through my inkjet printer many times, cutting off the printed area after printing. This may not work as well with laser decals- the heat does seem to affect the paper.
My paper feed does not work as well for small sheets- the paper starts skewing sideways a bit. So I prefer to run the full sheet width through. I lay out the decals arranged so that they are in a wide strip of limited length. Then I chop off the strip as square as possible so the next time it feeds as square as possible. A paper cutter works well for this.
usually waited to fill up the sheet, but just a tip: check the minimum duimension sheet that your printer can accept, or she just don't print it and get it out
rtoo speed makes ugly results, too relax don't make results
I always run a plain white sheet through also. I have one decal sheet that has several cut-outs from previous printing that I still can use. Use the plain to get the orrientation right and the size, then run the decal paper through. I use an officejet and havent had any probs with it jamming or skewing. m2
On the Bench:
B-29 Superfortress
1/48th A-6E Bomber
Welcome to Wal-Mart: Get your stuff and get the HECK Out!
Shut up, I'll Keel U!
It also depends on the design of your printer. If you have a straight thru feed, It will be less likely to damage the paper compared to a sharp "U" feed (like many HP Printers).
gunner_chris By tape would you suggest painters tape to reduce damage when peeling up or would that be too thick?
It shouldn't really matter. I've used whatever is close to hand---Tamiya yellow tape, 3M blue tape, even regular "Scotch" tape---and I've never had any problem with damage when peeling off. Low-tack painters tape works fine, or just avoid peeling and cut out the decal section with an Xacto knife. My printer is a U-feed HP, and I've run everything from full sheets to near postage-stamp size without issues.
Have fun. Making your own markings opens up whole new worlds of modeling possibilities.
