Decal water temp
    June 2010
Decal water temp
Posted by Temujin on Wednesday, April 4, 2012 4:22 AM
I don't know if this has been covered in here already, but I've got a tip that may be helpful.
When applying decals, I have one of those mini electric hotplates that are for keeping your coffee warm.
I fill a cup with  warm water, and by putting the cup on that hotplate, the water never gets cold.
    March 2010
Posted by Scorpiomikey on Wednesday, April 4, 2012 4:46 AM
I know warm water makes it lift quicker. But is it really better? Doesnt cold water work just as well? Just a bit slower.
"I am a leaf on the wind, watch how i soar"
Recite the litanies, fire up the Gellar field, a poo storm is coming Hmm
My signature
Check out my blog here.
    January 2006
Posted by RedCorvette on Thursday, April 12, 2012 7:32 AM
Some of the old thick Monogram decals definitely worked better with warm water.  They actually had a pressure-sensitive adhesive and had to be blotted down since they didn't repsond to setting solutions.  Using warm water softened them and helped them conform to the surface contours.
I don't don't use warm water for most decals, but I do use distilled water to avoid the mineral stains that you can get from tap water.
Mark
FSM Charter Subscriber
    April 2009
Posted by Cadet Chuck on Saturday, April 21, 2012 2:52 PM
Another good use for distilled water- use it as a final rinse after washing your parts in soapy water, then let it air-dry.  No spotty mineral residue!
    November 2008
Posted by plasticjunkie on Saturday, April 21, 2012 3:02 PM
Been using just regular cold tap water since the late 60's - early 1970's on my decals and it works just fine. I dip them in for a few seconds, pick them out with teweezers and set them dowm for the water to work. A couple of munutes later its ready to slide off the backing paper.
 GIFMaker.org_jy_Ayj_O
