help with decaling the 1/150 scale Cutty Sark
    June 2007
Posted by ronald305 on Saturday, July 14, 2012 4:18 PM
Hi there
   has anyone decaled the 1/150 scale Cutty Sark by any  chance I mostly need help with  applying the  long curve decal that goes on the back of the Cutty Sark with out damaging it   I  figured out to apply the numbers that go the hull  I had to order a second set I don't want to messthem up either can anyone help
                                       Ronald
Posted by Don Stauffer on Monday, July 16, 2012 8:36 AM
I frequently cut long narrow decals into sections to make them easier to handle.  I do have to match up the seams, but I find that less onerous than the problem of long decals folding or twisting back on themselves.  Also, put down a liberal amount of setting solution first.  This slows down drying and gives you more working time before they set.
    June 2007
Posted by ronald305 on Monday, July 23, 2012 6:18 PM
ok thanks Don --- the decal Im  fearfull of messing with is the one that has to make that turn at beack of the ship the numeral numbers I can handle
                                  Ronald
Posted by Don Stauffer on Tuesday, July 24, 2012 9:21 AM
Still think the best way is to cut it into two or three pieces.  Yeah, you have to maneuver pieces to match up properly, but that is still easier than a decal that has doubled back on itself.
