excited too try these solutions but still unsure of my results
    December 2012
Posted by Blaine Vanderwell on Thursday, December 13, 2012 11:36 AM
I would like a professional look on my kits and have read quite a bit of the pros and cons too using setting solutions....i guess its all in surface prep and patience....still gonna give these a try.....
    March 2010
Posted by Nathan T on Thursday, December 13, 2012 1:32 PM
You mean for decals? I find them a must on most decals. Just use a little at a time, expect the decal to wrinkle a little bit, then leave them alone to dry.
Posted by Don Stauffer on Friday, December 14, 2012 8:58 AM
Setting solutions are pretty benign.  There is little reason not to try them.  Decal solvents are something else.  They can be tricky- some decals dissolve completely in them.  I always use setting solutions, but only work with solvents when normal setting solutions- with repeated applications- just cannot get decals to nestle down.  Applying decals to compound curves is one place where solvents may be called for.
