plumline
After you scan them what do you do after that are you able to use them not sure how that process works.
You then need to make inkjet decals, using the scanned image as a master. The process is a bit involved, but if decals are not available otherwise it is a way to go. There is an article in FSM in the January 2013 about the process. Since I wrote the article, it seems Testors has changed "Glosscoat" a lot and sealing the decals has become harder. I am running experiments now on new methods of sealing.
