Probably asked this before but
    October 2009
Posted by Khalee2 on Tuesday, April 30, 2013 1:31 PM
I am starting to decal a british plane, the red center of the roundels is separate, would I need to seal the main roundel before putting the red dot on?.
Or would just waiting a bit for them to dry be enough? and then sealing the whole thing.
Posted by Bish on Tuesday, April 30, 2013 1:51 PM
You should be fine if you let the first one dry properly first. I usually do that even with decals that are close together. I have had German swastika's that are in two parts and don't have a problem as long as the first is properly dry.
    October 2009
Posted by Khalee2 on Tuesday, April 30, 2013 2:11 PM
good thanks.
