Cleaning up the model after decals are on...
Posted by Lufbery on Wednesday, February 25, 2004 1:26 PM
Hi all,
I've just finished putting all the decals on my current project. I used Micro Set and Micro Sol to help the decals snuggle down (and they did a great job!). This was all over two brushed coats of Future.
I read somewhere that after using setting solutions and/or solvents, one should wiped down the model to get rid of the excess before putting on a top coat of Future.
What should I use to wipe down my model? Water? How do I do it so that I don't take the decals off?
Thanks in advance,
-Drew
Build what you like; like what you build.
    January 2003
Posted by stinger on Wednesday, February 25, 2004 8:08 PM
I use a water-moistened Q-tip. First, I make sure the decal has had at least a day to dry. Start at the center of the decal and lightly brush the Q-tip out toward the edges.
Haven't had a decal lift yet using this method. In fact I use the Micro Sol/Set myself. One time I need to remove the decal, and trust me, no amount of water and rubbing would make it lift. I ended up having to sand it off and repaint!
stinger
May an Angel be your wingman, and the Sun be always at your six
Posted by Lufbery on Thursday, February 26, 2004 8:10 AM
Thanks, Stinger.
I'll give that a shot tonight. I was really worried that I'd mess up the decals I spent five nights applying.
Regards,
-Drew
Posted by Lufbery on Monday, March 1, 2004 9:15 AM
For what it's worth: I found an article from a 1999 issue of FSM, written by Paul Boyer, on applying decals. Paul recommends using setting solution to wipe up the excess solvent. I tried it, and it seemed to work.
There was no damage to the underlying coat of Future, and no problem with the top coat of Future that I put on after cleaning up.
Regards,
-Drew
