I'm not familiar with the Vallejo System,but the key to getting decals to look realistic is a good gloss coat,this prevents the decal from silvering,allowing the film to show.I use Micro Set and Micro Sol,probably the equivelants of what you have.i apply the decal over the gloss coat with water,then apply a little of the set,if it need to go over raised surfaces or down into detail,then I apply the Sol which is stronger.after everything dries,then cover the decal with another shot of clear coat,either flat or gloss,whatever your final finish will be,this protects the decal from the weathering process.
