Trimming Decals
Trimming Decals
Posted by Anonymous on Wednesday, March 3, 2004 2:27 PM
I have read that it is a good idea to trim your decals before applying. Now, does that mean cut them right up to the edge of the ink, or do you need a little clear edge around them to help them adhear properly??
Jake
    January 2003
Posted by shermanfreak on Wednesday, March 3, 2004 2:41 PM
Trim as close as you can to the edge, that'll give you the best results.
    February 2004
Posted by chris hall on Thursday, March 4, 2004 12:44 AM
Don't trim right up to the edge of the decal because 1) you don't actually want to cut into the decal by mistake! 2) a little clear surround helps the decal blend into the surrounding paintwork, when you're using decal solvents.
In my experience, most modern kit and aftermarket decals are fine as they are, so long as you use standard techniques: apply them to a glossy surface, use suitable decal solvents, apply a further coat of gloss varnish/ Future and then a final coat of matt/semigloss varnish.
Cute and cuddly, boys, cute and cuddly!
Posted by Anonymous on Thursday, March 4, 2004 12:28 PM
Hey Chris,
That's kinda where I was thinking too. Just one question though: The second coat of gloss you mentioned, would that be over the entire model like the first, or just over the attached decals?
Just clarifying,
Jake
    February 2004
Posted by chris hall on Thursday, March 4, 2004 1:30 PM
Hi Jake! Generally, gloss over the whole model. Varnish tends to darken the paint it is applied over,so not re-glossing the whole model could be noticeable. If you use Future, it dries quickly - touch-dry in an hour, overpaint-dry overnight.
An excepton is miitary vehicles and ships. Here you can often get away with just glossing the panels to which the decals will be applied (e.g. helo deck and hull on a frigate, but not the weather deck or masts). This especially applies if the modelwill be heavily weathered after the decals have been applied.
Hope this helps,
Chris.
Posted by Anonymous on Thursday, March 4, 2004 2:00 PM
It does, good to know. Thank you
Jake
Posted by djrost_2000 on Wednesday, March 17, 2004 9:41 PM
Just a little tidbit on decal trimming: Find a sharp pair of scissors that you can manuever well while cutting with, and don't use those schissors for anything else.Wink [;)]
DJ
    February 2004
Posted by chris hall on Tuesday, March 30, 2004 2:24 PM
Concur with that. I use a pair of surgical-quality toenail scissors, which I don't use for anything else, and replace them every 3 years or so (at which age, they're still fine for cutting toenails!)
Chris
